Old 09-21-2020, 04:03 AM   #1
10/10ths
"50 Years of 550 Spyder"
10/10ths's Avatar
Lock the car...
....When you lock the 986 it goes into “Deep Sleep” after 72 hours. This will significantly lower the battery draw.
You can test this yourself.
Lock your Boxster, then leave her for a week. When you return to drive her, try to unlock her with the remote control on the key fob.
You will discover that the car does not respond. You will have to physically insert your key in the door to unlock her.
Of course, you could also invest five minutes and read your owner’s manual. Just a thought. You spent a bunch of money on a semi-exotic German sports car, the least you could do is spend a lunch break with a cup of coffee and read your owner’s manual.
Good luck.
