Old 09-19-2020, 06:59 AM   #10
A 986 S
A 986 S's Avatar
My head unit was installed a couple of years ago so so, of course, the specific model that I have is an oriental antique. The Xtrons web site shows the current version is nearly identical cosmetically but has better performance and Android 10. It does have a capacitive screen and glare is not a problem on mine.
Adjusting the volume with the touch control is not that big a deal for me, at least after I got used to it. I'll admit to ejecting the CD and/or turning the unit off when trying to adjust the volume every once in a while until I climbed the learning curve a bit. Touching the little volume control on the side makes a big volume slider appear on screen. Easy to use while driving.
The ability to use the GPS speedometer is the best reason to get a head unit that runs Android. The OEM speedo always reads 3 to 5 mph fast. I ignore that and trust the GPS speed instead.
2002 Boxster S Orient Red Metallic / Graphite Gray
https://rx19jones.wixsite.com/a-986-s
A 986 S is online now   Reply With Quote
