Old 09-19-2020, 06:12 AM   #11
Starter986
1998 Boxster Silver/Red
The only reason I can think of is if they want to use original Porsche switches (for appearance). Those switches are momentary switches so a latching relay will be required. If you use a normal style switch no additional relay is needed.
Gotcha. Likely at some point that is the route I'll go. The $10 rocker switches aren't exactly meshing with the interior. However... I've got the setup nicely heat-shrinked... and kind of hidden nestled into that cubby under the steering wheel.
I believed my hookup to be somewhat complicated... and was wrong. I'll overcome the electrical fears and fashion up everything proper.
Then the paddle shifter mod.
Have a great weekend!
1998 Porsche Boxster
