					Originally Posted by  piper6909
				Yep.  Mine could be part-way down or all the way down.  Once I latch the top, they automatically go up.
yes, this is normal operation and that is working again...I think it was the position of the top (i converted to manual after one of the cables broke) and when I touched the switch, they went up, and starting action normal.
I am converting back to power and pretty sure I have that issue figured out. The window drop is likely the door latch issue common to others since the internal and external handle doesn't do anything and the regulator is tight.
once fixed, Ill share what I found.
