				window symptoms
			OK...maybe two problems, but here are the symptoms:
When I pull the center convertible latch, my windows don't drop, if I lower windows, when I close center top latch, windows close
Passenger side, lifting the handle on the outside or pulling the handle on the inside the window doesn't drop 1/4 inch, no noise, no slack to push the window down
this leads me to believe the center latch microswitch is working, but why no window drop on open?
Lack of noise and slack leads me to believe this isnt the window regulator, or handle microswitch as both would need to be bad?
drivers side window works fine with handle to drop windows 1/4
love to hear thoughts and experience
@particlewave? Can you save me and anyone else with this?
