Old 09-15-2020, 03:33 PM   #24
piper6909
piper6909's Avatar
I ran a wire from pin 85 to ground... and the high-speed fan kicked on (only tested one side).
Just purchased standard round rocker switch... but am thinking that even with the 5 prongs on the back of part #986.613.134.00 (Porsche Boxster Lock Switch Black) I could connect to two of the prongs and achieve the same result, correct? Wire to ground... wire to pin #85... abandon the other three prongs.
Yes? No?
That Porsche Boxster Lock Switch Black would look better than the rocker switch.
Thanks!
Those switches won't work because they're momentary switches. I.e. they don't stay closed when you pull your finger off them. An additional relay needs to be added to get those to work.
2010 Subaru Forester
piper6909 is online now   Reply With Quote
