Originally Posted by hstephenson
Is there any way to tell if it has been replaced?
If you're lucky you might find a decal like this one from LN Engineering. Otherwise, you could inspect the IMS bearing flange to see if it has been replaced. Some retrofit bearings use the OEM flange so you can't always tell by this method either. I think the most reliable source would be a documented service order from a reputable repair shop.
-RobT
Sent from my Pixel 3 using Tapatalk
