Old 09-14-2020, 04:04 PM   #1
Racer Boy
Racer Boy
Racer Boy's Avatar
As others have mentioned, the trailing arms on these cars won't cause your problems. Honda trailing arms have big squishy rubber bushings in them, the Boxster have a hard nylon bushings, so there is very little deflection. When worn, the Boxster trailing arm bushings make a lot of noise, but they typically don't affect the alignment to suffer.
I'd say rebuild your suspension before trying something like a rear sway bar. Maytag is right, until you get repeatable results, you will just end up wasting time and money.
