Old 09-13-2020, 07:58 AM   #2
blue62
Originally Posted by chromecarz00 View Post
I've spent about an hour googling though and haven't found an answer, so - I think it's time to make a post.
I just got my Boxster back a week ago (was living away for about a year and a half) and have experienced this issue again. The symptoms are as follows:
-Ugly "kazoo" noise at startup - starter motor hanging on the flyweek too long, from my diagnosis - needs to be lubricated, possibly replaced?
-Occasionally has a tougher time starting
-After filling gas once, would not crank. 12.5-12.7V on the battery, all lights on the dash, lights went off as though it was trying to start, but no click or crank or anything. I tried jiggling the key, moving the steering wheel all around, etc. I put it into service mode as I thought it could be the starter finally going kaput, and about 10-15 minutes later, it fired up - no jumping, no checking of fuses, no moving - all I did was put the top into service mode.
Now I've seen this could be a number of things - immobilizer, ignition switch, starter, fuses - but I'm hoping that the fact that without doing anything, just a few minutes later it was able to start fine helps narrow it down? If immobilizer, I can do the rubbing alcohol trick. if fuses, I can replace, but if the fuses were out then it wouldn't start later right?
The car is a '98 5-speed Boxster, ~95k miles
In the last 15k miles, I have replaced the ignition switch and battery - so I am more confident that this is ok.
Any advice is appreciated!
Do a search here on the forum.
There are three or four threads currently discussing the issue.
