Old 09-12-2020, 07:37 PM   #5953
piper6909
piper6909's Avatar
Originally Posted by Zzorro View Post
Started the O2 sensor swaps. I'm doing all 4. They are seized in there pretty good. So ima gonna let them soak on PB Blaster overnight. The garage smells of persuasion and progress
Yes, I got the O2 sensors removal socket. Anyone got any other tips?
The O2 sensor socket may flare out and round out the sensor if the sensor is really stuck. Cut the wires and use a deep-well socket or a 7/8" box wrench, if you have room. Use the O2 sensor socket when you install the new ones.
An impact helps or tap the wrench with a hammer to shock the threads. For extremely stubborn one use a torch to heat them up.
Use COPPER anti-seize on the new ones not silver.
Good luck.
2010 Subaru Forester
