Old 09-11-2020, 04:29 PM   #13
blue62
Originally Posted by Tinkerer View Post
This is the a recent invoice if that helps looks like new coil packs have been tested but problem still persist.
Interesting:
I see why the shop is looking at cam timing.
I would want to verify proper camshaft timing at this point.
Along with proper function of the variocam system.
You could have an issue with the wiring harness from DME/ECU to the coil packs
the connections to the DME/ECU or the DME/ECU itself.
Testing all the above shouldn't be to hard for a shop to do.
As for living with the problem and continuing to drive the car.
It's not something I would do.
But it's your car and something only you can decide.
