Old 09-11-2020, 03:31 AM   #263
sniktaw
Originally Posted by EuropaDrive View Post
I suspect that you must have tapped into a switched 12-volt wire to power your unit, that turns off after a few minutes, such as the trunk light. Best would be to put a voltmeter on the +12V wire, lock the doors and see if the voltage drops after 5 minutes...
Sorry should have started originally that I had same thought and thus wired direct to +12V at battery to double check - sadly, same outcome ;o(
sniktaw is offline   Reply With Quote
