Old 09-11-2020, 02:33 AM   #262
EuropaDrive
2004 Boxster
Originally Posted by sniktaw View Post
Hi Guys,
fitted one of these today on an 04 MY using the BN/WH & BN/RD wires under the seat at the immobiliser and everything works a treat. However, 5 minutes after locking the car it cannot be opened using the new remote (as described by others here). The unit operates but the car does not respond. Anyone resolved this issue?
TIA, Darren
I suspect that you must have tapped into a switched 12-volt wire to power your unit, that turns off after a few minutes, such as the trunk light. Best would be to put a voltmeter on the +12V wire, lock the doors and see if the voltage drops after 5 minutes...
'04 986 Atlas Gray / Boxster-red / Blue top
EuropaDrive is offline   Reply With Quote
