			I'm hoping they offer to start all over but it's more likely they will first try just tightening the drain plug and tell me to come back if it continues to leak.
I can almost guarantee they DID NOT use a torque wrench to tighten the plug to the 35 ft/lb spec.  Since I don't wrench myself I wonder how many ft/lbs someone with just a wrench and arm strength would typically tighten the drain plug..... my guess is without a accurate torque wrench they might not tighten the plug enough to "crush" the washer enough to make a good seal.....or conversly they made it too tight and damaged the crush washer..........no idea.
I suppose tomorrow at the shop will tell.........
