Old 09-09-2020, 05:44 AM   #1
I_like_tacos
no crank, no start
Hey all,
I have a 2003 Boxster base (MT) with around 68,000 miles. The car has been having a no crank, no start problem. When it happens, I have full power, the gauges move and I hear the fuel pump. However, when I turn the key nothing happens. No crank, no start. Rowing through the gears and removing/replacing the key gets it started but sometimes it takes a little while. I have replaced the battery, clutch safety switch and the ignition switch but the problem remains. There are no other electrical problems, just the no crank, no start. I would be grateful for any advice anyone has. I'm not sure where to go next (except a shop). Thank you!
I_like_tacos is offline   Reply With Quote
