10-24-2006, 03:00 PM
#2
Guest
Originally Posted by MNBoxster
Hi,
You can push the car in 5th or 6th - this gives you the greatest mechanical advantage, to try it in 1st, you'd have to go all Ahhhhnold on it. Without a Timing Belt, you could push the car either way, but forward turns the engine in it's proper direction, not a big deal either way w/ no TB.
If you keep the alarm on all winter (which I don't recommend), you'll be drawing considerable power from the battery and make the Maintainer work alot harder (maybe more than it was intended for, the battery too for that matter. But, so far as the Key Fob is concerned, it's the Car's Alarm, not the Key which goes dormant. You don't need to start the car to reinitialize it, all you need to do is unlock the car with the key, that will wake up the car's Alarm to accept the Key Fob signal. Hope this helps...
Happy Motoring!... Jim'99
PS It should read - First, if a Manual, put the car in Neutral and push it back a few feet. Then, place the gearshift in 5th gear and push the car forward, this will rotate the engine. If you run out of room, say in a garage, go to neutral again, push the car backward, and repeat procedure so you're sure one complete revolution of the engine has occured.
Excellent, thanks, Jim!
OK, I thought when the car goes dormant, and you use the to key to open the door, you had only about 30 seconds to start the engine with the key before the alarm sounds, since the car wants to make sure you are the "owner" and have the key vs. someone who just "broke" in? I guess I am wrong?? I need to read my owners manual more!!
