Old 09-07-2020, 06:04 AM   #1
986 Boxster
986 Boxster's Avatar
Originally Posted by 1PorscheBoxster986 View Post
If you have stock halogen headlights then you have the standard reflector lens. You are definitely blinding someone with the high beam on unless you have severely clouded headlights .
The Litronics come with the projector lens. The headlight's beam path is adjustable but only for low beam and fog. The owner manual has instructions on page 229; full tank, stock tire PSI, 165lb driver, and about 25 feet away from wall.
If you do decide to upgrade to LED bulbs you should have it professionally calibrated for a street driving car. Different state has different leniency. Otherwise spend the money for Litronics and help your eyes.
The headlights are are brand new, maybe 4 months old, I found where to adjust them, thank you. I`m going to adjust them later on when it gets dark out.
I looked into getting litronics, but all the ones I found come with the clear bottom turn signals, I like the yellow at the bottom of my headlights, somehow it blends in nicely with the color of my car.
986 Boxster is offline   Reply With Quote
