Old 09-06-2020, 06:09 PM   #155
Homeoboxter
Originally Posted by Qingdao View Post
I LOVE using heat when installing bearings and press fittings. I started using heat to the extreem to press in ball joints at work last year. I used to just use a ball joint press, but now I just cherry red the spindle and pop the joint in by hand. Then cool the crap out of the joint asap (yes I have melted the plastic bushings in the spherical joint once). It makes for a PERFECT press fit.
Yeah, heat/cooling is a gentle way of assembling parts. When I work on motorcycle engines I just heat up the cases in the oven and just drop the cold bearings in the bores and they slide right in. The less force the better
