Old 09-05-2020, 11:50 AM   #8
Gilles
Originally Posted by spemato View Post
I have loosened the x6 subframe bolts but am guessing I need to separate the steering shaft from rack at least before dropping, do I need to undo strut top mounts?
Hello Craig,
No, you don't need to separate the steering shaft from the rack, but you need to remove the bolts that secure the rack to the subframe, if I remember correctly I held the rack to something above it (cannot remember what..) with a couple of zip ties to keep it ouyt of the way. Good luck!
