Thread: Winter Storage
Old 10-24-2006, 02:05 PM   #13
bmussatti
Guest
Posts: n/a
Jim, this is your advice for the spring:
"You can do this in one of two ways. First, if a Manual, put the car in Neutral and push it back a few feet. Then, place the gearshift in 5th gear and push the car forward, this will rotate the engine. If you run out of room, say in a garage, go to neutral again and repeat procedure so you're sure one complete revolution of the engine has occured. This will loosen any frozen engine parts (such as rings, chains, etc.), without the extreme torque of the starter motor. This torque is so great that it can tear rings or do other damage. If you have a TipS car, take a large socket on a breaker bar and turn the crankshaft pulley bolt clockwise to rotate the engine. "
I still don't get this! Can I do this on my own, or will I need to enlist the help of the Chicago Bear's front line to push my car?? Can I have the car in 5th or 6th gear and push the car backwards...down the driveway?? Or do I need to really go forwards?
OK, what if I store the car with the battery maintainer (I am not taking the battery out) and lock the car so the alarm is on. In the Spring, if I open the doors with the key (since the fob won't work with that much time past) how do I get the car pushed in gear to get one or two engine revolutions before the alarm turns on, because the car was not started soon enought with the key??
Thanks!
