Old 08-31-2020, 08:34 PM   #20
beater986
Beater...
Have you considered that bar you're designing... upon which you'll mount the lights... fabricating it in a manner so that it "plugs in", if you will, to the tow hook threads. That would be the only mounting point... and the part that screws into the tow hook bolt hole, the piece that will be mated to the bar... that mounting point (weld, bolts, nuts, whatever fastener) could be hidden or nicely finished.
No?
The only problem is I can't stop things from rotating, and having all of that mass of the bar relying on a single point is going to cause bounce.
The goal is still to have the bar removable in < 3 minutes back to stock so it can be thrown on quickly for excursions.
Here's progress:
Light spacing measurements are a bit off, but things are going well. Printing the (hopefully) last version now.
beater986 is offline   Reply With Quote
