No; the Airlift system is just plugged into the tank fill opening and will pull vacuum if the system is closed; if you are not getting vacuum, something is open.
Any chance you are using an aftermarket tank with a built in leak?
gonna check the bleeder valve, it is an aftermarket provided by owner. hoping I dont need parts
