Old 08-30-2020, 05:52 PM   #3
78F350
Motorist & Coffee Drinker
78F350's Avatar
I'd say no, don't do it. Don't even put weight on the wheels with that removed.
Now that you have the correct answer... I have done it with parts cars. Nothing broke and I did not die. It will cause the rear suspension to shift. You will have trouble getting the plate back on (use a ratchet strap and/or pry bars) and the alignment will need to be checked when it is all back together. Straight and level. Short distance. Slow.
Best answer, still no.
