Finding a coolant leak
2002 tip, 80k
Car started dropping coolant right rear. Obvious coolant tank leak and wouldn’t hold vacuum after draining system. Replaced coolant tank, everything went in fine.
After replacement, used my trusty airlift and it just sucks air, no vacuum. Airlift works fine, tested that and good seal at filler neck. I have a hole somewhere and can’t find it. Any usual suspects here from others experiences. Plan on trying smoke to see where I’m drawing air. I’ve heard the burp valve is bad in new ones sometimes, that would be nice.
Thoughts?
