Old 08-29-2020, 10:19 PM   #12
JFP in PA
Originally Posted by flmont View Post
Could I pull the spark plug tubes and then use a bore scope to get a good look..??
and would a Bore scope that connects to your phone work,.?? Thanks Frank
You would still only be able to see the chain rail pads on the little rails between the cams; you will not be able to see the other units as they are too deep in the engine to realistically get a bore scope down there without getting it stuck.
