Old 08-29-2020, 09:22 PM   #9
78F350
Motorist & Coffee Drinker
78F350's Avatar
Check the date on the tires: https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11&
Fresh oil and check the filter: https://www.pelicanparts.com/techarticles/Boxster_Tech/02-BASICS-Oil_Change/02-BASICS-Oil_Change.htm
Replace the water pump unless it has been done in the last 5 years: https://www.pelicanparts.com/techarticles/Boxster_Tech/34-WATER-Thermostat_and_Pump/34-WATER-Thermostat_and_Pump.htm
Then drive it, drive it, drive it, and maintain it. I'd plan to service the transmission and replace the IMS bearing within the next few years, but not urgently.
78F350 is online now   Reply With Quote
