Old 08-29-2020, 09:22 PM   #5
78F350
Motorist & Coffee Drinker
78F350's Avatar
Check the date on the tires: https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=11&
Fresh oil and check the filter: https://www.pelicanparts.com/techarticles/Boxster_Tech/02-BASICS-Oil_Change/02-BASICS-Oil_Change.htm
Replace the water pump unless it has been done in the last 5 years: https://www.pelicanparts.com/techarticles/Boxster_Tech/34-WATER-Thermostat_and_Pump/34-WATER-Thermostat_and_Pump.htm
Then drive it, drive it, drive it, and maintain it. I'd plan to service the transmission and replace the IMS bearing within the next few years, but not urgently.
