Old 08-29-2020, 09:03 PM   #7
Rickvd
Rickvd's Avatar
I bought an 04s automatic with 29k miles on it with an unknown maintenance history. In 3 years of ownership currently at 42k miles. I have did the 60k maintenance at 30k miles. Replaced the transmission fluid and this year replaced the water pump as there were signs of webpage. The ims has not been replaced. I routinely monitor the cam deviations lookin at how stable the readings are and have not noticed any indications to be concerned about. I would recommend a good inspection by a Porsche dealer or independent, change oil and filter, probably change the transmitting fluid. Make sure you check the tires as they might be weak do to age. Get a duramitic tool and maybe consider changing the plugs. But it sounds like you got a great deal. Have fun and out some miles on it.
Rickvd is offline   Reply With Quote
