RA1
I reread your first post and see the you have 106 thou. miles on it.
So if your motor mount has never been replaced it is toast. The center rubber part parishes rather quickly on theses cars.
Also if you have a standard transmission.
Push the clutch in at idle and see if the slight vibration changes in any way.
Also take it for a drive and push the clutch in at different speeds and see if there is any change in your whoosh whoosh sound. or any change in the feel of the car.
