Old 10-24-2006, 10:10 AM   #4
RandallNeighbour
Check these two things:
1. Check to see that your spare tire and tool kit are tightly secured in the front trunk. If either is loose, they will make a thud when you brake hard, accellerate hard or make hard turns.
2. Pop off your battery cover and try to slide it side to side. If it moves at all, the battery bracket (which screws into the bottom part, not the top as you would expect) is loose or missing.
I do hope it is one of these two things because they're a very easy fix, and might even be totally free of charge.
Don't worry, I take donations through paypal for my online advice Really I do.
