Old 08-27-2020, 09:26 PM   #10
Tonydileo285
Originally Posted by Boxtaboy View Post
Thanks. Well, being that this was the first time we tried this, we took our time, and it took us from start to finish about 3 hours, but that was because first, we noticed that a clamping rail on the b-pillar of the top had snapped, so we had to replace that first. Getting the old top off was pretty easy. There are only 3 bolts on each side of the frame that hold the top on the car, but you have to remove a couple of trim pieces near the b-pillar that protrude over the base of the frame where the bolts are. That takes about 10 minutes each side, but is pretty easy. Then after putting the new top in, you have to make minor adjustments to the positioning so that everything closes and opens properly without being off. What I mean by that is that there is some play in the positioning of the frame where the 3 bolts are on each side where you can actually move the frame forward/backwards up or down before tightening the bolts, and also the positioning of the pushrods that connect to the top from the transmissions. If you tighten the 3 bolts when the frame is too forward, the top latch hook will touch the windstop between the roll bars when you cycle the top. If the pushrod length is not just right, the ball caps will pop off when you operate the top. However, it's all very straightforward, and we could probably do the job now in under 2 hours.
If you end up sourcing an 03 or 04 top, feel free to PM me, and I can give you some pointers on the install (my friend who helped me put the top on actually is the one with the expertise, so I can put you in touch with him for some helpful tips). It really is a plug and play bolt in, provides a pretty large window, and doesn't limit access to your engine from the top (there's a built in strap on the top that helps hold the back of the glass window up and away from the engine cover when you need access), so I think it's a no brainer over the GAHH top if you can find one. The one thing I hated about my old plastic windowed top was that I never quite knew when it was too cold out to put down the top in fear of the plastic window cracking (which it did one day). This solves it.
Nuther pic to show you how nice and big the window is...oh, and there's PORSCHE engraved in black letters at the bottom center of the heated window.
So I just bought an 03/04 OEM Glass top for my '99 Boxter. A Lot of people on here are saying I need some new parts to accommodate the swap, including the new transmission gears.
My question is, do I really need that? Can it not just be a plug and play with the 99 Model car? **I have seen people convert their tops to MANUAL by removing a few parts, can't I avoid the need for upgraded parts if I install the 03/04 glass then do the mod to manually let the top up and down?**
Hope my question makes sense lol. I want to do plug and play then make the top manually operable, getting rid of the need to use the button/transmissions/etc.
Tonydileo285 is offline   Reply With Quote
