Old 08-27-2020, 06:13 PM   #10
Zzorro
Zzorro's Avatar
Thanks Blue62
One clarification, I have 175k kms or 108k miles. But same difference. The car is up there in age and miles and stuff needs replacement.
To answer your specific questions:
1: yes, will swap O2 sensors. Explanation of my rationale below.
2: yes, I can turn on SAI pump with durametric.
3: yes, SAI turns on on cold start, have confirmed it.
I am suspecting O2 sensors over the SAI because:
-all the other codes thrown
-smells to me like it's running rich on idle. Totally subjective opinion
-engine bogging issue (and subsequent CEL) happens after the car is warmed up and in higher revs.
-you pointed out that one of my O2 sensor heater elements is probably pooched anyways.
For the benefit of those joining in the conversation:
Based on my research on here and other places, the primary culprits are 1) MAF, 2) vacuum system (which the SAI plays a part in) and 3) O2 sensors.
1) I already replaced the MAF (and that made a huge difference). 2) The SAI functions and I could not locate a vacuum leak easily (idle drops when oil cap is pulled off and starter fluid sprayed near the hoses and parts did not blip idle at all). 3) Next on the list is the O2 sensors.
Should note also that I replaced my AOS already and that did get rid of blueish smoke on startup.
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
