Thread: Head bolts
Old 08-27-2020, 09:24 AM   #1
Gilles
Originally Posted by Dllrd23 View Post
Going to tear down to the crankshaft and at very least re-bearing the bottom end and send the heads to machine shop.
Dllrd23, If you are planning on rebuilding the bottom end you may want to consider re-sleeving the block with the Nickies as these blocks have a tendency to wear the cylinders with an oval shape and a set of new rings will not be able to fix it..
