Old 08-24-2020, 11:33 AM   #2
Gilles
Spend $10 and buy 2 cans of Gunk engine clean and get the area cleaned up.
Caution: do NOT use high pressure as it can cause damage to fragile electronics. Garden hose with a regular attachment will be fine, just judiciously use it around small items.
+ 1 on the Gunk tip.
Afterwards, I like to use Simple Green (diluted with water), to get rid of the oily residue of the Gunk. And using Low water pressure it's important specially around the connectors
You will love the way your engine looks and you will be able to find the source of the oil leak, good luck!
