Old 08-23-2020, 08:26 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
Those two codes are often caused by a vacuum leak - broken or disconnected hose for the secondary air injection system (SAI). There are plenty of threads here on the forum about the vacuum hoses.
The AOS could still be a problem, but would not likely be related to those codes as Blue said.
Generally the SAI system is only emissions related and helps to give a more complete combustion of fuel when your car is first started. If the failure is related to a vacuum leak that can cause your car to run poorly and should be fixed.
