Old 08-23-2020, 05:02 PM   #1
blue62
Originally Posted by mungodrums View Post
My 99 Boxter was delivered to me three days ago. Occasionally on start up a billow of smoke would come out of tail pipes. I thought bad AOS. Today check engine light came on, dammit. Went to Autozone the following codes came up: P0410 and P1411. Can these two codes be triggered by faulty / bad AOS / oil separator, think this is the same part, correct? Faulty gas cap? While car was idling, I removed oil cap and it was somewhat challenging to get off, felt quite a bit of vacuum. What do you guys think. Don't want to randomly put in new parts. Smoke test most efficient way to determine leak or issues? Very bummed out. Ger.
P0410=Secondary air injection system cyl. 1-3 signal implausible/implausible operating range/malfunction.
P1411= same thing on cyl. 4-6
I would start by checking to see if there is a related fuse that is blown.
Then find a wiring diagram to the SAI and check the wiring
Then test the SAI pump.
The AOS and other issues you mentioned are unrelated to the current codes.
How many miles on the car?
Has any recent work been done on it?
