Old 08-22-2020, 09:33 AM   #2
Gilles
Originally Posted by jamesa914 View Post
That was exactly the problem, and thanks for your tip. The ratchet strap (and a little bit of brute force) enabled me to get the triangle reattached. Everything is put back together, and I just got back from a test drive. Car is much smoother with new tranny mounts. Thanks!
James, you may want to check that the alignment on the rear axle is within spec..
