Old 08-21-2020, 07:18 PM   #1
jamesa914
It's my understanding that the 987 rear-end is quite similar to the 986. So you;re probably talking about the triangular-shaped alu 'pan' / brace that bolts front & back, and on the two uprights. And it's those latter bolts that you can't line-up, right?
When you lifted the car and let the wheels & suspension droop, especially for any length of time, those uprights will shift, usually (maybe always?) APART from each other. Many of us find that a ratchet-strap between the uprights will bring them back together enough to get the holes to line back up.
If I've misunderstood the problem you've described, then ignore ALL of this.
That was exactly the problem, and thanks for your tip. The ratchet strap (and a little bit of brute force) enabled me to get the triangle reattached. Everything is put back together, and I just got back from a test drive. Car is much smoother with new tranny mounts. Thanks!
jamesa914 is offline   Reply With Quote
