Old 08-21-2020, 05:28 PM   #17
beater986
Are you dead set on having oval lights? If not than maybe a light bar might be easier to mount and lighter. I have a feeling that those lights will stick out farther than you expect. The weight and distance from a sturdy mounting point might make the lights bounce up and down like crazy. Just another idea, what about installing a third radiator hole on the bumper cover and mounting the light bar behind the radiator using the mounting tabs for the third radiator? Or cutting round holes into your bumper cover and mount the oval lights farther back and flush with the cover?
If you're set on mounting lights in front of the bumper, I would suggest mounting the light support bar either to the radiator support brackets or where the radiator brackets attach to the body
All super valid concerns, but I am dead set on the classic circular lights. Totally different aesthetic than light bars. The circular lights pay homage to Porsche's rally roots and give a nod to cannonball.
The absolute easiest way to accomplish this would hands down be to use the RTS system mounting points on the A pillar, but again aesthetic.
I'm also dead set on having the completely returnable to stock form, so cutting anything is out. Though I could see how cutting the lights IN to the bumper might actually look very good.
Last, I want to create a mount 'system'. Where I can swap lights for camera mounting, or a jerrycan carrier, or something else quickly and easily. I also want the system to be detachable due to theft (serious problem, my truck was stolen and stripped of its lights and offroad stuff)
I approach these things from a productionization point of view as well. If I'm going to invest 100+ hours in research and $1000+ in CNC tube bending/maching for a prototype. If there is demand, I might make a kit available publicly to try to amortize those costs.
Originally Posted by 1PorscheBoxster986 View Post
This is another interesting project you're taking head on beater. I think it's time to rename your Porsche Boxster to Porsche Campster. I look forward to another thread when you add a grill to the trunk. It's already a warming tray by itself after a nice drive.
Ha. You're reading my mind. I have some ideas for a concealable hitch system where a luggage rack (or other) can be mounted at the back.
beater986 is offline   Reply With Quote
