So after a couple more troubleshooting sessions the shop has pinpointed the issue as the VarioCam actuator like we originally thought. Mechanic took the current actuator apart and there was apparently some silicone blocking the oil feed port. It’s unclear where this came from but he thinks it’s from a previous time the valve cover came off with a past owner.
He put the car back together and it runs MUCH better now and I was able to drive for an hour yesterday with no codes.
Unfortunately, eventually a CEL code came back for bank 1 timing adjustment. I think the actuator may have been damaged due to lack of oil or is working intermittently. Going to drive it for the weekend if the code keeps coming back we will put a new actuator in and hopefully have this issue put to bed.
