Old 08-20-2020, 02:31 PM   #8
outsidetheboxster
I am 6'2", 24" inseam, 36" waist, 240#, and I ran a Recaro Profi XL seat floor mounted all the way back, floor mounted (no slider) on Brey Krause 9044 mount with integrated sub bar. If you aren't tracking you could replace the 9044 mount with a 9042 [Edit: actually call them to see as I'm not sure the holes line up the same, I only know the 9044 works as that's what I have) if you didn't need the sub bar.
The seat is pretty comfortable, and plenty of leg room and headroom. If you are ever down in North FL or near any of the tracks I visit, you are invited to come sit in it (they are now in my Cayman but the fit is very similar.) [Edit: now I see you are in WA so not likely ) But I bet there is someone there that has this configuration, I know several folks down here that run it, it is a popular config]
Steve. Appreciate your information on the set up. I do actually get to Florida once in a while to leave via Miami. Really too far to travel just to try out a seat but I appreciate the offer!
Recently figured out that mine have power adjustable back angles, at least the passenger side does at this time. I may be able to get by if I can figure out how to fix the drivers side and get it to adjust at least one last time.....
Thanks again!
outsidetheboxster is offline   Reply With Quote
