Old 08-19-2020, 04:34 PM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
I don't think there is anything wrong with that arm in your picture. The ball socket attached on the end in your last photo snaps into a square black plastic piece (part #26 in the diagram) which slides in the track. It is a bit of work to get the #26 part out but you may be able to get it snapped back inif you unbolt the arm from the clamshell.
Right, That arm is cast aluminum and more likely to break than bend. I don't think that the ball will pop back in, but the whole track is just held on with two bolts. Undo the rear bolt, pop off the washer and (26) slides right out with (18) attached.
Pics in a little bit. I have the parts.
