Old 08-18-2020, 04:47 PM   #1
aparke4
2002 Boxster S Bay Area
Hi all-
I recently purchased a cayenne for a DD and I need to let the boxster go.
2002 Boxster S
Meteor Metallic Gray
Clean Title
1 Key
99.460 miles
No Leaks
Always 91+ Octane Gas
Small dent in front left front fender from me backing my truck into it (doh!) no rust but since it was my DD I have not fixed or gotten a quote (see pics) no rust.
Front lower bumper lip and plastic guard is pretty beat up but no major damage... looks like lots of parking spot bumpers and curbs have taken their toll over the years.
New tires front and rear in last 6k miles
New brakes F and R professionally done with braided DOT approved brake lines with under 2 k miles
New belt at 95k
Recently detailed with hybrid ceramic coating (not full ceramic coatig)... clay barred and waxed recently as well.
Custom fit car cover
fully operational top with top in excellent shape. Rear vinyl window is clear.
clutch done around 84k... IMS was inspected by shop in San Jose and deemed OK.
Oil changes with syn every 4 k... LN Eng oil filter conversion with K&N oil filter and quick drain oil plug for easy oil changes
Transaxle fluid changed with Royal Purple at 90k
Renntech rear lower strut bar and tie downs/ OBX rear upper strut bar and Renntech Carbon fiber front strut bar
New battery at 93k
Alpine apple car play headunit at 94k double din plus 4 4.5" speakers added to car: two in rear and two in center console. Car has premium speaker with mid bass in doors... sounds pretty good!
Bens easy install quick shifter plus metal shifter side from uniwerks bundle "make it easy"
https://uniwerksdesign.com/product/make-it-easy-porsche-shift-bundle/
Bens carbon fiber TB intake plus nearly new 74mm TB from 911/ cayman + custom Cold Air intake sealed to body inlet
https://uniwerksdesign.com/product/porsche-986-carbon-fiber-intake-plenum/
Second cat delete pipes with flowmaster HP-2 mufflers... sporty sound and not too loud but some drone at 2700 rpm... was going to have exhaust shop build a custom cross over pipe to cure completely
LED rear tail lights like 987 era smoked
LED bulb interior conversion
LED Frunk and Trunk Bulb Conversion
LED from headlight bulb conversion
New iridium plugs at 94k... coils looked nearly new
New AOS for maintenance purposes at 99k
Volo VP-16 Remap tuner... not sure if it really does anything but it comes with car already updated to new firmware
New t-stat low temp at 95k with flush and fill cooling
New updated oil pressure spring from 911 (beveled + spring)
New MAF at 96k for maintenance purposes
Some rock chips and one larger dime sized one on rear qtr
Paint in excellent shape... I did not even need to color correct!
twist 18 inch wheels
Fabspeed rear jack point mount
comes with separate rear crash bar i was intending on making a stealth hitch out of for a bike rack. mid project.
Asking 11k OBO
Please txt: 4 zero 4 - 2 2 six - three zero two 1
Located in Bay Area
aparke4 is offline   Reply With Quote
