Thread: Radiator fan
Old 08-18-2020, 10:52 AM   #2
piper6909
piper6909's Avatar
I did not. Can you point me to the instructions for that procedure? Is that something that can be donw without removing the bumper cover or the wheel well plastic?
Thanks, Pipe.
According to this video, you can get to it by removing the inner wheel well. You won't have to remove the bumper cover.
https://www.youtube.com/watch?v=XsPeDvJXEUs
In this video Burner's high speed was working, so he determined that he had a bad ballast resistor. In your case, if NO speed works after you jump the pins, it could be bad wiring or a connection or it could be the motor. But I'd check the wiring first.
Here's another link that shows you how to access the fans:
http://www.pedrosgarage.com/Site_3/Replace_Radiator_Fan.html
Another fairly easy test is to see if the fan spins freely.
2010 Subaru Forester
