					Originally Posted by  edc
				If you removed the battery it would have been best to prop open the front boot. Same if you disconnect it. Try the other wheel liner to see if the cable is there.
I believe the red fuse tab needs a battery connected to complete the circuit.
+1 on this ^
If the battery is disconnected, i don't know how you'll get that frunk open, unless you can find that cable.  There should be a manual release cable behind the front bumper. Mine stretches across under the right side headlight.
