Old 08-15-2020, 12:30 PM   #2
99Roadster
The plate acts as a brace between the rear suspension, as maytag said, you do not want to put any weight on the rear suspension without the plate installed. If you are tracking your car and need to change the transmission oil frequently, some people drill a hole in the plate below the drain plug so the entire plate doesn't need to be removed.
Thanks everybody for your reply's.....Yeah I wondered why they would only put a hole for the fill but not for the drain.
99 Roadster base / 5 SP Tiptronic
18" Turbo Twist wheels / Arctic silver W/Black leather Int
Rear wing W/Brake light / 47,000 miles
Side skirts / Bought from original owner
99Roadster is offline   Reply With Quote
