Old 08-15-2020, 06:34 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
The plate acts as a brace between the rear suspension, as maytag said, you do not want to put any weight on the rear suspension without the plate installed. If you are tracking your car and need to change the transmission oil frequently, some people drill a hole in the plate below the drain plug so the entire plate doesn't need to be removed.
