Old 08-14-2020, 01:08 PM   #26
sfkjeld
sfkjeld's Avatar
A solenoid is just an electromagnetic device.
It could have been tested with a multimeter via back probing the wiring connections.
Also the function of the actuator can be tested with a OBDII scanner that has test functions.
With my $175.00 Foxwell scanner I can trigger my actuators then not only hear the difference in how the engine runs.
I can also see the cam timing change and by how many degrees.
Very simple tests that verify function.
Thank you, very interesting. I recently purchased a Foxwell scanner, probably at your suggestion. I’ve used it only to clear the CEL. Are you able to see the timing change on the scanner?
sfkjeld is offline   Reply With Quote
