Old 08-14-2020, 11:47 AM   #3
Jgkram
Had the same problem a couple of years ago and went through similar process. Checked fuel, spark and air. Thought it might be a crank position sensor but checked the voltage and it was reading ok as well. Ultimately went back to test the fuel pressure again and in the process of testing the fuel pressure, something let loose and she started. Never really could confirm the problem but I suspect the fuel pressure regulator was stuck not allowing enough fuel. Who knows. Anyway replaced it and have had no issues for several years now. It's my daily driver. Good luck and sorry I could be no more help.
Jgkram is offline   Reply With Quote
