Old 08-14-2020, 07:13 AM   #31
Jager
Jager's Avatar
Tim, you're getting good help here from Jager, so I hesitate to interrupt.
However:
I have seen oil (in small amounts) get to the air filter due to a bad aos, when combined with a poorly running engine.
Under normal conditions air only moves in one direction through the intake tube. However: if your engine "backfires", even just a slight stutter or a cough, then yes, you can see air moving the other direction, though only momentarily. I wouldn't worry about it at all, for the moment, as you could end up chasing squirrels that aren't there. I would focus first on your AOS, then on your vacuum leaks.
Then let us know how it goes.
No doubt backfires would throw oil onto the air filter if you had oil in the intake/throttle body. I have not seen that since I have never had a Porsche motor backfire.
So Tim, has your motor backfired??
Jäger
300K Mile Club
Jager is online now   Reply With Quote
